Re: Ford style girdle
Art
Is there a possibilty of a girdle for 215 olds with turbo or supercharged v-6 caps? $? |
Art,
Check with Sean over on the SBB board on V8Buick. He has my 340 template. JB |
Re: Ford style girdle/up in the air.
Thanks Jim. David, If you can make the caps fit the Olds block, why not ?. As I think through this, not many will be willing/able to cut down stock main caps to flush with pan rails. I'm NOT suggesting this either. Therefore, for the aluminum blocks, I think 7075 T6 plate of .50-.75" thick, shall best serve the purpose. This is thick enough to "relieve" for the caps, and still have adequate strength. No blanchard grinding required and quite good "yield" strength,(52% greater than 4130 ) ! Onward, roverman.
Edited 2 time(s). Last edit at 09/19/2011 08:10PM by roverman. |
Art
Sounds like what I'm looking for. How much $, Installation details? Any oil sump mods? I'm having pan made now with wings and baffles. |
Art, sounds good. Keep us up to date on your progress, might be something we should consider when we build the "race" motor for the RV8 next year.
Re: Ford style girdle/ .750"
Clan, just like this months' Hot Rod mag. Will add .75" to pan rail height. Main studs will need long enough for nut above/below girdle. Will have provision to use modified oem style 5/8" pick-up,ie. mount flange bolted to girdle and tube protruding into block, with precision fit. I don't suspect "side oiler" is neccessary at this time. Material is ordered to build (5). I will post,first article. Onward, roverman.
Edited 3 time(s). Last edit at 09/26/2011 12:50PM by roverman. |
Guys,
SCCA requires the 3.5 Rover block for my GT2 Rover RV8 - specifically, in the General Competition Rules. The girdle might allow me an extra 1,000 rpm or more and provide for competiveness in the GT2 class. I'm building a better Rover 3.5 (SCCA legal) engine for the coming year and would greatly benefit from a girdle. Keep up the good work. keep them on the track, phillip g |
Re: Ford style girdle,(deep "Y")
Phillip, Maybe "Mike" can chime in here, I thought BL Motorsports "had" a 3.5L block with cross bolted mains ? Are you forbade x bolted mains ? I saw "rally" blocks at the factory, in 83". They were "filled" for x main potential. Got girdle ? I find no logic for using a single nut, on top of a sheet metal pan, to retain the girdle.My design will have a flush nut at pan surface, to retain girdle,use "Sealtite" for hassle-free sealing and teardown and another nut on top of pan. Good Luck, roverman.
Edited 1 time(s). Last edit at 11/04/2011 12:30PM by roverman. |
