Roverbeam Chad McNeely N.E. MO (76 posts) Registered: 06/09/2021 06:03PM Main British Car: Alpine S4 Rover 4.0 |
Re: Max valve size for 4.0/4.6 heads?
To add another data point to the chorus, Erson specced 130/300-325 for a recent hydraulic roller cam.
I'm using 300 heads and the Ferrea Buick 6000 valves, so my spring choices to get those pressures have no relevance to your search, though. Edited 1 time(s). Last edit at 01/06/2023 12:53PM by Roverbeam. |
Apparently there's not much metal to cut the pockets deeper. Dustin didn't feel comfortable with going .050" so we seem to be limited there. Next option: Offset retainers. We need to look for a beehive retainer with a .100" offset. I think the stems are long enough and if not then lash caps can make up the difference. 0.680" diameter on the retainer, 10 degree, 0.100" offset. I sent an inquiry to CC, nothing back yet. I imagine somebody does have it.
Jim, Here is another experiment for you. Crane used to sell the same retainers for both 11/32" and 3/8" valves. If I recall correctly the height would go up if using the 11/32" and down with the 3/8". Don't know if it would be enough though. Try one of your other Beehive retainers on the rover valve and see what the difference would be? What would the difference be with the 300/Oddfire V6 valves? I think you mentioned they would be 1/16" taller
Dave was talking about having a Rover cut up head maybe he can answer how thick the seat is. Another thought for another thread, maybe someone who has a 300 head and a Rover head can make a tempate to see if we can copy the Buick accessory mounting on the Rover head by drilling and tapping?
At the bottom of the page, there are 4 pics of a cutaway head.
[www.v8forum.co.uk] Ever see a Rover V8 sawed open to show the coolant passages? :8 [youtu.be] |
Based on those photos I wouldn't have any issue with going an extra .050" deep. Makes the offset retainers easier to find too.
Dave, Great work! Did you see the Dodge Viper V10 springs I mentioned above. They are for 1.75 installed height. These are also 1.7 height:
[www.summitracing.com] Edited 2 time(s). Last edit at 01/09/2023 12:07PM by mgb260. |
Those and a few other springs would be highly suitable…
But the pressures still seem a little on the high side unless you are going to be turning some big RPMs or using heavier valves??? I’m just flat running out of time right now unfortunately, otherwise I would be purchasing a 11° Carbide mill and Setting up to machine some retainers to 11 degrees. Maybe on my next set of heads! Edited 1 time(s). Last edit at 01/09/2023 01:02PM by turbodave. |
Hey Jim,
It is indeed a 11-degree (22 deg included) but you need one with a major dia of at least .590" dia (and a minor dia of .400), so none of those will suffice; it'd be a custom piece. There isn't enough info on the comp site to make a drawing unfortunately. I can purchase a set on amazon and measure them up to see how they would work (and return if its a no-go), but if you assume that you would use a reamer and set it up to just clean up at the bottom of the existing 10 degree, you are radially increasing the diameter by approx 8 thou at the height that the top of the spring would be sitting (or 16 thou on diameter)! I think though, there still isn't enough installed height - you're still going to be digging material out of the seat pocket in the head. I have seen offset retainers in the past; not sure if they were for 10 degree though; obviously the further up the top of the spring, the wider the keeper/lock/collet so you start losing diameter… Edited 2 time(s). Last edit at 01/12/2023 07:31PM by turbodave. |
I just confirmed with Tim that the 10 degree keepers that TA sells have in fact the Chevy type groove. Dave was right, no help there.
Still no luck I suppose on the tapered carbide reamer? Might be easier to find in the reamer category as opposed to the end mill category. Creating a carbide tapered reamer is not a minor undertaking, but not impossible either. For this job I would start with about a 3/4" round stock in mild steel, cut the taper, make relief cuts to locate the carbide, and then braze pieces of carbide in position. Then back to the lathe to grind the taper with a tool post grinder, followed by grinding the relief angles. Using 3 edges would give a self-centering action although it could also contribute to chatter. Finding the pieces of carbide is as much a challenge as anything, however here is one source: [www.carbideanddiamondtooling.com] They would need to be roughly about 3/32" thick, .200 wide, and 5/8" long but the above ones should work. Jim |
I ordered some of the carbide pieces, after they come in I'll see about making up the body of the tool. I have everything else here that I need to make it.
Hey Jim,
II just ordered some of the retainers and will draw them up and verify there is enough meat in them to make this happen. Cheers Edited 1 time(s). Last edit at 01/20/2023 07:53AM by turbodave. |
OK Dave, if it looks like it'll work I'll cut your retainers if you'll send me a second set for my own use. Does that sound fair?
Anyone have cut-up pic's of the 300 alum. head ? I have such a head.
Art. |
