Re: Max valve size for 4.0/4.6 heads?
Dave, I like the 980 modified the best. On the 795, what bothers me is the valve tip is so close to the retainer. If it was milled flat on top it would be better. The keepers are a lot longer than most and the part below the retainer won't hurt anything.
I don't really see any problem with the 795. As long as the valve tip sticks out any above the retainer nothing is going to hit. The part of the keepers that stick out below won't hurt either as long as they don't hit the seals.
Well, I guess I’ll speak with my local shop and see what they want to machine these on their Haas lathe. After initial set up we’re talking less than 2 minutes each, so can’t be all bad.
Edited 1 time(s). Last edit at 01/22/2023 11:20AM by turbodave. |
Yep, let us know.
What is the diameter of the valve stem at lock ? The stem is 11/32" but it is thinner at lock position. I was just thinking if it would be possible to modify the smaller 7 degree 5/16 locks by removing the tang. In other words make it look like Buick/Rover lock ?
Dave, here you go:
[www.racingsprings.com] Edited 1 time(s). Last edit at 01/23/2023 11:55AM by mgb260. |
Dave, I was thinking of just clamping the retainer in the drill press vice. Dressing a 9/32" Cobalt bit down to .278". I think the taper will stop any spinning. You just want to take the ridge off and hone it out a little. Once drilled, shut off drill, lift up and remove locks.
Edited 1 time(s). Last edit at 01/23/2023 12:15PM by mgb260. |
I am sure if drilling as a pair you’ll want to put a known thickness shim or gauge wire between the two (on the flats) to space them apart, and press down to seat them and prevent spinning. Rethinking it, that would probably be pretty easy to achieve, just a little fiddly with the shim, but totally do-able. Doing as a pair would stop the drill walking and be a LOT quicker of course!
McMaster has metric colbalt drills I’m sure. I do have a few metric R8 collets so will probably just use my mill. How great is this that the .277 is right there at 7mm? Nice idea Jukka ! Edited 1 time(s). Last edit at 01/23/2023 12:14PM by turbodave. |
That is what I hoped the TA locks were! Actually, if you use a 7mm bit and they are touching, they won't be when on the valve stem because it is slightly larger diameter.
Edited 1 time(s). Last edit at 01/23/2023 12:32PM by mgb260. |
Good idea but it will be fiddly and tricky to do. That spacer between the two halves will have to be an accurate thickness so you don't cut into the rest of the bore and your clamping device will have to press the halves into the taper pretty firmly. You might make your spacer as a long tab that extends out the bottom and just drill away the center of it on the first set, then deburr and continue with the rest. That way the bottom part would make it way easier to insert as a single shim rather than two individual ones. Might want to make the shim out of aluminum.
But how to clamp it? Maybe something like a big nut that the retainer will fit into? Then a hollow bolt in the top that will press only against the keepers? Drill through the open center of the bolt. Has to be a step in the nut for the retainer to sit on. Draw something up Dave and I'll throw out some more ideas. Jim |
I'll throw something together in 3D to make it easier to visualise.
Based on my playing with locks in the past few weeks, I'd have thought we're only talking about 4-8 thou a side. That'd be not too difficult to cut into 1/16" wide strips. If cut to 3" lengths it'd be pretty easy to slide in there. |
Jim or Dave, You guys can check the gap on the stock Rover pieces. For a shim, a pop or beer can is around EDIT.004 thick so a piece doubled would be about .008.
Edited 3 time(s). Last edit at 01/23/2023 04:29PM by mgb260. |
