Re: MGB Roadmaster/ in-ground-effects ?
Sorry to give the game away, Jim B, but I think I recognize an "inverted wing", when I see one ? Pretty crafty ! This should tend to offset the added unsprung weight, hey hey ? Keep em flyin low, roverman.
Re: MGB Roadmaster
Shh!.. No point in telling everything. Anyway looking again I think the unsprung weight is closer to 3-4 grams per side, certainly much less than the difference made by shaving the tread.... not that any of us would do that.
JB |
Re: MGB Roadmaster
NO Jim, say it isn't so. None of our group would shave the tires, some of us would let them wear down to the point that the original tread pattern was more of a shadow than actual tread though. Makes running in the rain a bit dicey but hey when it's dry they stick like glue. I did change mine when I got back to KC this year though, how about you Carl, those Toyos still on your B?
Re: MGB Roadmaster
What's this, ground effects on the Roadmaster?!
Shaved tires? Only racers do that. ;) Tread squirm, ya know. Slick Toyos? Yep, just like you saw 'em at Townsend. Awesome on a day like today! Edited 1 time(s). Last edit at 03/08/2022 08:18PM by MGBV8. |
FLIPSMGV8 Phillip Quinn Reidville, SC (15 posts) Registered: 04/21/2010 10:01PM Main British Car: 1978 MGB Rover 3.9 V8 |
Re: MGB Roadmaster
Hello, Steve, Jim & Bill as we say down south the check is in the mail. It's not big but maybe you can pick-up some of the small parts for the car. One question, is the little car still at Jacks for the electrical are has it moved. Steve after it is done and if you get to have it in Lugoff, I sure would like to make a few more pic's before it gets gone. A any rate you guys stand by for the bumb question that I will be asking.
Regards Phil Quinn/flipsmg |
Re: MGB Roadmaster
Phillip,
thanks for the check (not here yet). I hope to have the Raodmaster here between Max's and returning it to KY for shack down. I'll let you know. Steve |
Re: MGB Roadmaster
Forgot. I was in Blowing Rock last Thursday and tried the new Thermo housing on the Roadmaster. It will fit but the dist will have to be re-aligned. The Vacuum advance is in the way now. I left it with the car. It should make it much easier to fine an upper rad hose.
Steve |
Re: MGB Roadmaster
Sounds good Steve. We expected that the distributor would have to be clocked to move the vacuum advance away from the filler.
Re: MGB Roadmaster
Phillip,
Your check came in the mail today. It is one the way to the bank since it wasn't enough for me to skip the country with. thanks for the donation. Steve |
Re: MGB Roadmaster
Steve, I know it's not much but every little bit helps. Maybe next time I can add a few zeros to the check and you can skip out with the RoadMaster and the cash. Us it well! I will go up to my shop and open up a few more cans and bags to see what falls out. Thats my where I keep my rat hole money but most of the time it's just a rat that falls out. Regards to all.
Phil/flipsmg |
Re: MGB Roadmaster
The Roadmaster is currently residing in Durham, NC at Flying Circus English Cars where Max Fulton and crew will be tackling the wiring and interior issues.
Re: MGB Roadmaster
I finally got my act together & boxed up the rear bumper/brackets, wiper arms & map pocket. Shipped out yesterday; should arrive @ Steve's on Thurs.
Re: MGB Roadmaster
I'll have to track it when I get home from work. The expected delivery date was today.
Re: MGB Roadmaster
I know Max is hoping for some help on the leaks in the air bag system like we tracked down on yours and mine Steve. The new parts should do it, plus he was asking about upgrading the compressor to a Land Rover pump. That should work very well and if it does as good as I think it will, you might ask him if any more are available for your car and mine (at bargain prices of course;-). Might be a good time to swap out the control arm struts too.
JB |
Re: MGB Roadmaster
Rob,
It has arrived. They put in a defferent place at the house. I did find, now I just have to find room for it. It will get to Max's though. Thanks for the parts. Steve |
Anonymous User ( posts) Registered: 12/31/1969 07:00PM Main British Car: |
Re: MGB Roadmaster
Posted by: Anonymous User
Date: August 22, 2011 05:52PM
Thanks Arthur, quite interesting to be sure, great post
Re: MGB Roadmaster
I'd like to catch up on some photos and progress reports. There are a lot of photos but unfortunately all but the last few are way too big and the last ones have the wrong file extension to upload, but I'll try to see what I can do.
As an update though, Max and his work crews have worked magic on the car over the last few weeks, installing wiring, interior, and finishing up the car with the exception of a few items that we will have to take care of over the winter. My understanding is that we need to bench bleed the brake master cylinder, rewire the alternator, and do a few more things before the car can be driven. At this time we are finished at Flying Circus and the car will soon make it's way back down to Steve's place in Lugoff, SC. We've not worked out the details of how long it will be there or when it will come back up here, but I think we can all offer Max a huge round of applause for his efforts in making this stage of the build happen. We are much more than just one step closer, we now have a complete car that, in Max's words, needs a few minor repairs. Thank you Max! JB |
Re: MGB Roadmaster
Roadmaster is now in lugoff, SC. Stopped on the way home and had the spreaders installed. One job done: Cost $0. Nice folks at Turner Glass.
A big thanks to Mike Speer for the loan of the trailer and another to Tom Caine for using his truck to tow it from Durham. Thursday I will try to get the brakes working and then on to the carb and timing. After that is the altermator and the temp guage. Used my comperssor to pump up the front end to unload and had no troulble. Steve |
