Re: LS4
Looks like enough of the ring gear is showing to engage a starter, and there may be some threaded bosses in that area that could be usable. It's on the same side as stock MG so no rewiring is needed and there should be clearance to the frame rails. It doesn't look to me like it would be any more difficult to mount a starter there than on the other side, it is the more conventional location of the two and avoids filter interference. I think I'd have to try that location to see if it could be made to work.
Of the transmissions mentioned, what do they have in terms of torque ratings and gear ratios? Are we talking exclusively about manual 5 speeds here, or are there other options? Jim |
Re: LS4
Jim, I got your gears turning! You already know about the Jeep/Isuzu AW4 automatic. The 5 speeds listed in order of strength: R154 Supra 1000HP twin Turbo,Colorado/Solstice 450HP,More in custom setups, shifter location fixed with R154 shifter mod, LS conversions.W58 about same as T5 300-400HPpopular in Australia with Dellow conversions,AX15 probably same but low 1st gear,forward shifter(truck/Jeep),AX5 weakest and also truck/Jeep.
Edited 1 time(s). Last edit at 02/21/2013 05:20PM by mgb260. |
Re: LS4
The 2.2 was originally FWD transverse in the Cavalier. So when GM converted it to RWD for the S10 they kept the FWD starter location and crank flange location. That is why the 2.2 bellhousing works so good to convert 3100,3400,3500 FWD V6 to RWD. The LS4 crank flange was shortened 3mm to mount transverse. It may have been to make room rather than match the FWD setup. I am going to know soon whether its the same or a crank flange spacer will be required.
Re: LS4
Lots of 5.3 LS4 motors on Ebay and car-part.com for $800-$1200 average. Double and triple that for the Camaro/Corvette ones. You can find the truck iron ones and switch over to car intake and front cover. They have the different cams and heads also. The LS4 comes stock with the best LS6 heads. LS4 factory dyno chart:
Edited 1 time(s). Last edit at 02/21/2013 06:10PM by mgb260. |
Re: LS4
So I take it, if Dan for instance were to go shopping for parts to put one of those in his TR7 he'd want to get a 2.5 Jeep Wrangler bellhousing, the W58... out of what Toyota? The LS4 out of a Pontiac or Chevy and then would have to sort out the starter and flywheel, does that sound about right?
And what vehicles were the R154 used in? Jim |
Re: LS4
Jim, The Jeep Wrangler 2.5 bellhousing would work for the W58 found in late 80's Toyota Celica Supras with a stock LS4. W58 is smaller than the others. The Dodge Dakota 2.5 bellhousing will fit the later 90's Toyota Supra and some Lexus R154 and Colorado/Canyon forward shifter/Solstice/Skye rear shifter. The Colorado/Canyon/Solstice/Sky Aisan tranny is the most common and a very good transmission, almost identicle io the R154 with better syncros, Mallet does LS6 450HP swaps in Solstice. They use common GM input and yoke. They have around 3.7 first gear where the older Toyota has about a 3.2 first ratio. So I would recommend higher rear gears. You might be able to shorten Solstice shifter housing to move shifter about 3" forward or use on Colorado to move shifter back 3". Picture of Solstice tranny.
Edited 2 time(s). Last edit at 02/22/2013 12:45PM by mgb260. |
Re: LS4
I've looked long & hard at that engine. Seemed to be the most economical LS engine, The starter is what stalled it, though. I'm not keen on the Toyota trans gear ratios, either. I would rather keep my T-5.
Only 300hp, so? That's double what I'm working with now. ;) |
Re: LS4
It's getting real interesting here, Jim. I may have to ditch the old 215, yet.
Gotta scat. I'm off to Durham, NC for the MG Roadmaster work weekend at Flying Circus English Cars. |
Re: LS4
Re: LS4
Here's my idea for an LS4 starter solution. First, I want to say that I am very interested in Jim's idea as I'm using a 2.2 bellhousing on my V6. One thing I want to avoid though, if possible, is modifying the starter. It would be nice to buy an off the shelf unit in the event of a failure. Went through that with my alternator on the way back from Palestine. (ask Jim and Dan) I'm also not keen on using a block plate, I need to keep the engine as short as possible. So while I'm keeping my eye on Jim's progress I've been thinking about the following approach for quite some time.
I'm thinking that this starter, the picture is from the JEGS site and is one of their Preform mini-starters, would be a great starting point. There are a million of these available on Ebay as well. Notice how the starter gear housing is offset from the rest of the starter. It's really hard to get a sense of size from all the pictures I looked at and I looked high and low for the dimensions of one of these but couldn't find any. (if anyone is using one of these and could get some measurments that would be great!) To me it looks like the gear housing is less than 2 inches in diameter. If so, then the starter gear would be well less than an inch from the edge of the housing which would be good for the LS4 situation. My idea is to modify the aluminum plate used on the starter so the starter gear snuggles up to the flywheel ring gear. This picture shows the passenger side of the block with no bad art work in the way. In this very bad mock-up picture, the blue image represents the aluminum plate the starter is bolted to. The purple stuff could be angle iron..or something heavy/strong so the starter won't shift/move once it is bolted in place. The left most purple thing shows a hole at the very top, that is the bottom bellhousing bolt hole, which goes through the block and requires a nut at the front to keep it tight. I don't know the size of the bolt but it is very beefy. On the right side of the picture, the hole labeled "Drill Block" would require drilling the block. The aluminum is pretty thick in this area so it shouldn't be an issue. There probably won't be enough room to bolt the angle iron to the front of the block but there should be plenty to bolt it to the flywheel side. You could use shims between the angle iron and starter to ensure the starter was absolutely parallel with the flywheel. You will notice something labeled "partially grind off" in one of the previous pictures. This picture gives a better idea of what I'm talking about here. This is cast into the block and it appears it might need to be partially shaped so the starter will fit. Depending on how extensive the shaping is, this would be a good place to anchor a brace that you could bolt to the bottom of the starter aluminum plate to further stablize it. You could even add a brace of some sort from the block to the front of the starter housing like some of the earlier SBC starters used. The goal of this approach is minimal modification to the block and no block plate. It would be nice to keep the 142 tooth flywheel in my case but you could go with the 148 tooth S-10 flywheel which would give you about a 1/4" (give or take) more flywheel to work with. It's about a 1/2" larger diameter than the 142 tooth. I hope this is somewhat clear. It's really hard to discribe something like this. Does this sound crazy or possible? I'd be interested in any feedback from the group. Anyway, there has to be an easy solution to this. It is just a matter of finding it. -- Scott |
Re: LS4
Jim, here are some pictures of the other side of the block. Not sure if you have any of these. Hope they are helpful.
Here is a view of the bellhousing side Here is a view of the oil filter side Here, the 6" mark on the tape measure is centered on the crank. I believe the 142 tooth flywheel is just a shade less than 12" in diameter. Regards -- Scott |
Re: LS4
Scott, those pictures help but, could you back up a little and get a good shot of where the starter would go. Your idea might work if you grind that tab all the way off and grind staight up. I do have a good picture of factory LS V8 starter mount.
Edited 1 time(s). Last edit at 02/22/2013 06:33PM by mgb260. |
Re: LS4
I like Scott's idea ,but in the drawing instead of the square starter mount,use a 3/8" steel plate. Bolted to the bellhousing bolt and block and with a tab also bolted to the thick boss. Then instead of using the mini starter drill 2 mounting holes for the Northstar starter. May have to have a spacer to line up teeth. A rear mount to oil pan rail would probably be a good idea also. Ugly drawing but kind of like Jim Bs idea. Drawing doesn't show tab bolted to boss.
Edited 5 time(s). Last edit at 02/23/2013 08:49AM by mgb260. |
Re: LS4
Jim N, I like that one. Run a gusset from the bottom over to the pan flange bolt and you have a nicely triangulated and rigid mount, and there are a variety of starters that would work with it I think.
Re: LS4
This is a fascinating thread! My question is about the ECU. Would you be able to use the ECU that came with the donor car? I am putting a GM 3400 in my TR6 and we are using the original ECU and engine harness. We have stripped all the extraneous stuff out of the harness and we are getting the ECU reprogrammed. Would you have to do the same for the LS4 ECU or is there an easier route?
Cheers Byron |
Re: LS4
Jim N, here's a wider shot showing more of that side of the block.
It looks like it is possible to grind the block a little to gain some room in the area down and to the right of the bellhousing bolt. I'm still having difficulty in seeing how the Northstar starter is going to fit in that space. It would be helpful to know the dimensions of it. Next time I get to the junkyard I'm going to go looking for one. It would be great to be able to use it. -- Scott |
Re: LS4
Putting a flex plate or starter on the motor would help a whole lot in visualizing the mount. There may be plenty of room for the pinion to engage the ring gear but without the parts you can't tell. Another thing I noticed is the vertical hole in the fixturing boss along the pan rail. A close fitting pin there could allow the large bolt to be the only fastener needed on the mounting plate, because they are in opposing planes.
As an alternative, if you look at the bellhousings which have a starter bulge in that location, they do have attachment bolt bosses. Maybe not in the best locations but below the block attachment there are a couple available so a simple aluminum plate of the correct thickness attached to the bellhousing using those bosses should also work quite well. Possibly the mounting plate could be combined with the dust cover for additional rigidity. Jim |
