Phil Crawford Philip crawford Bogalusa, La (80 posts) Registered: 02/01/2013 10:38PM Main British Car: 74 TR6 07 4.8L |
74 TR6 upgrade
Hi,
I started this project over 2 years ago and am getting close to being finished but still a lot to do. I started with building my version of the rotisserie. It was made from 2" 11 gauge box steel. The gears are from a ww1 navy metal lathe. I will be making post as often as possible and will try to answer any questions you may have. Thanks for looking. Phil Crawford Edited 1 time(s). Last edit at 02/02/2013 11:18PM by Phil Crawford. |
Re: 74 TR6 upgrade
I lifted the body off using these holes in the body and it worked well. |
Re: 74 TR6 upgrade
I have a trolly system in my shop to move stuff around. I live in a rural area and don't have much help moving things. I lifted the body off of the new frame several times during the build, it was nice to just do it and not have to wait for help. . Edited 1 time(s). Last edit at 02/02/2013 11:00PM by Phil Crawford. |
Re: 74 TR6 upgrade
I don't think I could have done this job with out the rotisserie. I am too old to be crawling around on the ground. Replacing a little metal and I guess dirt dobbers like TR's too. I cut out the old metal and welded in some new. There is no shortage of rust on these old cars you just have to deal with it and cut back the bad metal and weld in new. |
Re: 74 TR6 upgrade
I am welding the seam on the rear fender and this is part of it. Took the rotisserie off to do a little work on the rust around the lic. lights. I am building a complete frame and this the platform I intend to build it on. I squared it and leveled it and bolted it to the floor with anchors in the concrete. You can see the motor and trans. in the back ground. It is a 4.8L lsx out of a 07 chevy truck that a tree fell on it. It has 23k miles and its drive by wire with a 4l60e trans. Welded plate where the wheels go. |
Re: 74 TR6 upgrade
Started to mock up the front end. The front edn is a mustang II after market from speedway with a generic cross member. I bought the generic cross member because I new I would have to cut it no mater witch one I bought. Set the body back on to check clearance with the wheels. The wheels came off of a mustang. Got them on craig's list. They are 245/45 R17. |
Re: 74 TR6 upgrade
Had to trim a little metal but very little. The after market Mustang II after market are really good front end that are reasonable to purchase, repair and handle very good. Once the overall with was figured I cut the excess out of the cross member about 5 inches. Put the pieces I cut off on the inside and welded them in through 1/2" holes in the member then I butt welded it up. Once the cross member was welded and aligned on the platform just the was it sits at ride height it was welded to the platform. |
Re: 74 TR6 upgrade
Starting to look like a front end with a motor. Laying out the frame rails. They taper towards the front. They are 2" x 3" 11 gauge about 1/8" thick and they are very strong. Making these compound cuts took a lot of grinding and fitting but came out well. Just another view. Had to narrow the rack the same amount as the cross member. The alluminum ends are pressed on the tube and are not real hard to remove but the area where they sit is a smaller diameter than the rest of the tube. Also had to shorten the rack shaft and rethread the ends. My lathe is the same age as I and like me it doesn't look real good but it still works ok most of the time. |
Re: 74 TR6 upgrade
Put the body back on and making body mounts. Extending frame forward and looking steering. The steering was a night mare. Cutting some rusty metal out and getting to make the hole a little bigger. Had to kick the frame up and reduced it is size to 2x2". |
Re: 74 TR6 upgrade
Making sure everything fits. Upper body mount and upper four link mount. You can see the upper four link mount. I drilled a 3/4" hole then took a piece of 3/4" bar and drilled a 1/2" hole in it on the lathe. Slipped it in the hole and welded it in place. Makes a strong mount that won't collapse when tightened.. This is the removable trans. mount done the same way as the four link through bolt. |
Re: 74 TR6 upgrade
Thankyou for this detail. It needs a lot of knowledge and tenacity.
Over here in the wet, I'd be thinking about painting the frame with POR15, and coating it internally with wax. Likewise the shell. Perhaps not an issue for you. Hard to imagine living where it never rains. As I write, the water is dripping into the sump of our drainage system in the basement of our 400 yo cottage... Ivor |
Re: 74 TR6 upgrade
Hi Ivor,
I live in south louisiana and know all about rain and heat. I spent 2 years in Banbury I think it is in Oxffordshire many years ago and know about your weather. I am past the painting stage but thinking about foam filling the frame but don't know much about it. The car is painted and I am wiring as we speak but I have a lot more photo's and post to come. Thanks for looking Phil |
Re: 74 TR6 upgrade
Rob,
Thanks for looking. Just finished gluing veneer on the dash have to take some photo's. Phil |
Re: 74 TR6 upgrade
Phil welcome to British V8! I have seen all this stuff on the Six-Pack forum and it is so good that It is worth a second viewing! Phil I like your shop, you definitely have the space and right tools to get the job done.
Cheers Byron |
Re: 74 TR6 upgrade
I live not too far from you. I know there is a V6 mgb in sela I see sometimes, and my V6 alpine, Glad to see another one in these parts.
Re: 74 TR6 upgrade
Don
It has been a growing experience and have learned a lot. I believe my wife will be happy when I finish. Thanks for looking Phil |
Re: 74 TR6 upgrade
Byron,
Good to hear from you and how is your car comming. You must be close to finishing. I have been wanting to post on this site but just haven't had the time but finally decided to just do it. How is the weather? I wore short pants in the shop with the doors open. Good to hear from you. Phil |
Re: 74 TR6 upgrade
Robbie,
Thanks for looking and where do you live? Phil |
